RS2 Timing belt change - advice
  • enneeffe
    • May 2011
    • 7
    • Country: Italy
    Hi everybody
    I need to change the timing belt of my RS2 and I need a simple advice.
    How can I unscrew the main pulley bolt without having the VAG tool to block the pulley?
    Is there an alternative method to block it?
    Many thanks!
  • Boghopper
    • Aug 2010
    • 136
    You may be able to undo it with a BIG air gun, 3/4" drive, but its the tightening up thats the problem.
    It needs to be very tight and accurately torqued to avoid failure of the bottom sprocket at a later date.
    Pete
    Audi RS2 Volcano Black, MRC chip, Milltek exhaust
    • enneeffe
      • May 2011
      • 7
      • Country: Italy
      I tried this way some time ago with my Urquattro but:
      - the air gun I have is not powerful enough
      - using a big torque wrench the engine moves and I cannot unscrew the bolt
      I had to buy the VAG tool, but I don't want to waste money because I would use it one time only.....
        Vag tool is cheap in comparison to repair damage from a broken bottom pulley.............
        • Dobby84
          • Feb 2011
          • 1169
          Will the VAG tool used for an rs2 work for an s2? if so where would I get one from?
          • Ducky
            • May 2006
            • 636
            I undid mine by bracing the torque wrench on the floor and turning the engine over on the starter (albeit v.slowly).
            • Donnie
              • May 2010
              • 112
              Not on an s2, but I've done it by jamming the brakes on (with some sacrificial wheel bolts) using a board wedged between the drivers seat and the pedal and obviously having it in gear - works no problem. If ypu can't move the bolt, a trolley jack under a 3/4 breaker bar will budge it just be carefull with your bumper.
              • Dobby84
                • Feb 2011
                • 1169
                So is there no tool for the 3b? Or if someone has picture+dimensions of a homemade one that would be great.
