ECU PIN Number
  • urq20v
    • Sep 2003
    • 218
    ECU PIN Number
    A friend has an Audi A6 2.5 TDi with a failed injector pump.To replace the pump,which is coded to the immobiliser,the ECU PIN number is required.Dealers are capable of generating the PIN code from the VIN and immobliser code numbers,but dont want to give it out unless they do the work.I can use my Vagcom to get both the VIN and the immobiliser numbers,but not the ECU PIN.
    Does anyone have access to a system that will generate the ECU PIN number?
  • spink
    • 4382
    what is the engine code?
    • urq20v
      • Sep 2003
      • 218
      I have asked for the engine code,but being a 2002 auto,it should be either AYM or AKE according to ETKA.
      The VIN is WAUZZZ4B52NSS0784.
      • spink
        • 4382
        ok i will ask someone for you later today
        otherwise it may be possible with 'vag tacho',it is available cheaply and can get various codes
        • urq20v
          • Sep 2003
          • 218
          Thanks for that! :-)
          • spink
            • 4382
            sorry Rex i cant get it for you.just realised i have the gear to do it myself but need the car infront of me which may be a problem as you are 1000 miles away or more from memory.
            • urq20v
              • Sep 2003
              • 218
              Thanks for trying James.Yes,I am a little too far away for a personal consultation. :-)).
              I will have a look at Vagtacho. What is the best site to download the software from? Tried a few sites but I always got a virus alert!
              • prj
                • Mar 2010
                • 6308
                You need to buy the cable off eBay.
                • urq20v
                  • Sep 2003
                  • 218
                  Yes,I have seen the cables on Ebay and they are not the same as a Vagcom cable either.
