Before my car was mapped, only had 0.4bar boost, I had a problem where I was getting a fine mist of oil blown past the oil filler cap. I changed the pressure regulating valve and the one way valve in the PCV system and it seemed to cure it, no more oil mist. Since the boost has now been turned up to 1.4bar the problem is back, but worse. The cam cover is pressurising and blowing oil past the filler cap, and I'm getting quite a bit of oil blown into the MAF hose. I have 2 questions:-
1. What part of the PCV system is failing to allow this to happen? I've checked the one way valve and it seems ok, not sure how to test the pressure regulating valve.
2. Can the std system cope with a bigger engine ( 2.5 stroker ) and a bigger turbo, GT3071 with 1.4bar boost?
