coil kit upgrade time
  • dreft
    • Mar 2008
    • 8
    Hello,
    Im upgrading to a better coil kit and I'm wondering what might be my best options are,
    I'm running 2bar+ and 8000 rpm 500-600 HP. ABY.
    034 hade their High Output kit:
    And im also seeing alot of people running with 1,8T/2,0T VAG Coil Packs.
    For example the kit EFI Express got, and Swedish guys at Nascom: http://www.nascom.se/produkter2.php?...Prod=711&Col=1
    Pros and cons?
    Can you run the VAG coil packs with the cover on? I read something about cooling.
    Hoping for some helpful tips,
    Best Regards,
    Markus
    Audi S2 Avant 550hp Adolf
    You shouldn't run the 1.8t/2.0t coils under the ABY 20v Turbo cover. Trapped heat will kill those little coils real quick.
    Apikol has a plug and play 1.8t kit for less money that your Swedish link (not including exchange, shipping and taxes)
    That said, at your HP levels, 034's HO coils or all new OE coils and POS would be the most reliable.
    • jade
      • Jan 2005
      • 1811
      Originally posted by dreft
      Hello,
      Pros and cons?
      Best Regards,
      Markus
      Hi
      I recommend you deal With Marc at EFI Express he does a kit
      RS 2 580HP
