Since there is some time this subject came up and meanwhile more strokers hit the road with JP's (RWD19T) as the latest addition i thought that maybe the time is right to discuss this subject.
What ignition advance should one expect with a stroker engine compared to the original 2.2?
Of course there are many factors that determine the ignition advance an engine needs to run in order to have max/safe power.
I was comparing 2 engines with similar engine specs but with major difference in the flow of them (mine and JPs) and the difference was massive and i would like to hear what the others run.
Mine: At 4000 RPM and 1 bar i run 18 degrees that go to 22 at 7000. (mapped on the road with no dyno monitoring)
JPs: At 4000 RPM and 1 bar 23degrees and at 7000 32 degrees with 0.85 bar.
