Dr.Schrick Camshafts on AAN.
  • popdemonic
    • Dec 2007
    • 1304
    • Country: Thailand
    Recently,i just got the Dr.Schrick Camshafts from my Bros.
    He already sold his UrS6 so this camshafts are just
    laying around for a year.the camshafts was purchased
    brand new with only 1,000miles on his car.He said
    he feels no any significantly gain any extra HP
    on his car.The gas consumption is real horrible things.
    his car was bone stock at that moment.Well,Now
    i got the pair of Camshafts free of charge so What
    would i expect any gains from 260degree Dr.Schrick
    on AAN?My car has GT2871 with 034's dedicated
    software,Full 3" Exhaust.I did search from STFA but
    found so much less infos talking about Dr.Schrick
    Camshaft on Audi Cars.Bimmer seems more infos
    on Dr.Schrick.I'm just on the way thinking to put
    this camshafts or go for 7a with the better top ended
    result since I'm not funny with paying twice on mechanic
    labor charge.TIA.
    one of a few I5 from Asia.
  • JP
    • 1858
    If they are the schrick turbo cams you will gain top end if the headwork supports the higher lift and there is no restriction in intake/exhaust setup and remapped to suit. You will however loose low down and mid range.
    UrS6 Stroker + HTA3586 =
      Cam Swap info
      Pop: Changing cams is about an hour job and can be DIY. Only tricks are the loosening and tightening sequence and lining up the sprocket marks. (You start with the engine set at Top Dead Centre (TDC) on No.1 like at the start of a timing belt job).
      If you have the Schrick cam specs, i.e. lift and duration, you could compare them to the info in this post: http://forums.quattroworld.com/s4s6/msgs/87524.phtml
