Cambelt Change - Torque Settings
  • APNess
    • 479
    Hi all - the ease with which the crank bolt came out leads me to think mine wasn't 450nm - but everything was in fine condition with no problems. From walking out to the garage and getting the tools out to all belts off and new ones to go on - about 40 minutes
    So...
    450nm for new bolt torque?
    The 4 bolts holding that whole thing (about 3 pulleys and crank pulley) together - what torque setting for that please?
    Hoping to set a new world record for I5 timing belt change (helps with no aux rad of course, and 5 minutes flat to get front off) as it's raining on and off/blowing a gale and I'm getting rain down me **** crack
    Cheers all
    Paul J
    'The Bacofoil Express'...
    No more.
    Leon TDI 150 run in now.
    Very slow.
    Needs a chip.
    WAY too much information there big lad
    • APNess
      • 479
      Cheers for that m8 - what torque for the 4 bolts holding the pulleys together? Or will 'tight' do?
      Raindropskeepfallingdownmebum
      No more.
      Very slow.
      Needs a chip.
      • APNess
        • 479
        And one more thing before I finish my tea and get wet again (though now the sun is shining - this weather report was brought to you by...)
        332 lb ft in 'old money' is 450nm give or take, yeah?
        No more.
        Very slow.
        Needs a chip.
        • SteveH
          • 4460
          Off the top of my head, 25nm for the four allen headed bolts that hold the vibration damper to the cam pulley wheel. Make sure you use some thread locking compound, just in case
          91 Modded 3B
          14 A6 Avant Black Edition
          • APNess
            • 479
            Aye cheers - the tensioner bolts turned disconcertingly past 12lb ft without clicking (supposedly 15...) Left 'em at that rather than do the old 'shear off and swear' trick.
            25nm doesn't seem much for those 4 on the pulley either - they may have been thread locked up or something I guess - Will do at 25 anyway ta Steve.
            No more.
            Very slow.
            Needs a chip.
            • Markus
              • 184
              My swedish repair manual (found it on the net, but seems very official) says 20 Nm + 1/4 turn (90°) for those four allen bolts.
              Markus
              '94 Kristallsilber-metallic S2 Avant.
