I am trying once and for all to overcome my running issues and need to try a maf as it is a bit suspect, If anyone is in the areas above and would not mind lending me a maf for 5 mins it would be very much appreciated.
@montez... make sure to unplug ECU before the MAF swap - just so it starts without any history of adaptation. By the time MAF is swapped you can then plug the ECU connector on again.
