Top tip:
When removing the engine, get labels and label up every electrical connector you unplug. Life will be so much easier when the engine goes back in
Actually I think I'm there. I am sure I remember seeing a picture of the colour coded connectors lined up under the strut brace noted with all the sensors they are attached to on a thread somewhere...
Anyone can link to it? Or help me with a list of where each should go? I think I have most on correctly, the loom kinda sits in the right position to make it obvious, just a few I was unsure about:
Blue = N80, correct? the only other behind there goes to the coolant sensor on the back of the head at the moment.
There's two plugs by the IM, one black and one white - I believe it's the black one to the brown intake temp sensor atop of the IM, and the white one to the ISV?
