044 fuel pump instalation question.
  • K Simmonds
    • Dec 2007
    • 7627
    Right, I've used the search function and can't find a satisfactory answer regarding the pressure damper located on top of the original fuel pump. Is it required when fitting a 044 pump to a 3B?
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    i didn't use mine mate, just use a cap nut for the top
    • K Simmonds
      • Dec 2007
      • 7627
      Cheers Alex
      1994 MTM RS2.
      2000 B5 TQS.
      • DS2
        • 80
        • Home: Jordan Current: Finland
        is there any reason not to use it?
          IIRC - the pressure damper is only relevant to old school KE-Jetronic installations... you just use the cap dome nut on RR, 3B, AAN, ABY, ADU !
          • K Simmonds
            • Dec 2007
            • 7627
            Yep, space is quite tight once an 044 is instaled, the damper may well touch the access panel on top of the tank. I'd like to know why it's there though, later Coupes don't seen to have them.
            1994 MTM RS2.
            2000 B5 TQS.
            • DS2
              • 80
              yeah i thought it might be tight in there
              • K Simmonds
                • Dec 2007
                • 7627
                My 1990 3B had the damper. However the pump may have been replaced as it has the same part number as a C3 100 Avant turbo pump I have knocking round.
                1994 MTM RS2.
                2000 B5 TQS.
                  because 'later coupes' dont have K-Jetronic... they all ECU controlled (of various sorts)
                  • K Simmonds
                    • Dec 2007
                    • 7627
                    Errr, no offence Paul, but I'm sure all 3B's are Motronic as opposed to K-jet. Though like I said I don't know if the pump is original.
                    1994 MTM RS2.
                    2000 B5 TQS.
                      no offence taken... but I am 99% sure on the pressure damper thing... parts system only called it up on K-Jetronic from memory - will have to look at it again in case my memory is munged.
                        I guess its just a hangover from the earlier cars, 7As have these dampers too and are not K-jet.
                        Out of interest Kit, was the 044 a straight fit in the basket as it is with the 7As or did you need to buy the bigger basket?
                        • K Simmonds
                          • Dec 2007
                          • 7627
                          It was a straight fit mate. To confuse matters I had a look in the tank of my 1992 NG engine Coupe which is K-jet, no damper. Guess it must be a year thing.
                          1994 MTM RS2.
                          2000 B5 TQS.
                            I guess the early S2s shared the basket & hose assembly with the other models
                              LOL - another theory shot down in flames then - heheh... damned Audi confusion. Maybe its something they phased out over time then... or the older K-Jet cars where more sensitive to something that required the damper in place. Answers on a postcard to S2central.net
