Hy friends, my name is Eduardo ,and I need help from friends about dynamometers and audi rs2
we are working on a RS2 project and now is time to tune the engine, but I not have any 4x4 dyno close to me , only 4x2 dyno, because that I ask if is possible put this machine on a 4x2 dyno suspending the rear wheel or maybe turn off the rear differential?
Below have some detail about this project.
• Bullseye S366 Turbocharger
• Modified cylinder Head flow 129cm intake and 104cfm exaust @10'' 10mm.
• Dbillas camshaft 269 x 269 x 11,9mm x 112 lobe
• Custom made Race intake manifold large plenum with 70mm TBI
• 5x deka4 60lbs fuel injector on primary and 5x 160lbs on secundary
• fuel used is alcool (etanol)
• motor displacement is 2350cc ( 5x 83 x 86,4mm)
• the exaust is 3'' Stainless steel
• tubular Race Stainless steel exaust header
• HKS 50mm wastegate
• Forjed 144mm Scat rods and forjed 83mm Ross pistons
• Haltech sport 2000 ecu
• Custom made Steel block guard on main caps
Thanks in advance
Eduardo Guilhon
JJ-Competition
electronics specialist
Thanks in advance
Eduardo Guilhon
JJ-Competition
