It seems that they coppy garrett and borrow shafts from turbonetics....
"This specific Precision shaftwheel’s blades measure 1.4mm thick and this component is made in China by a company called Worldturbocharger, this company is well known for manufacturing “copy” products of OEM original Garrett, KKK, IHI, Holset etc – this company uses a material called K18 for the turbine head, which is a steel derivative with a high thermal ceiling, but by no means anywhere near the same quality as the Inconel 713LC material used by Garrett, KKK or Holset, hence the thicker blades on the Precision turbine, thicker blades simply mean more weight, and for any component which relies on its ability to accelerate, weight is not great. The shaft also appears to have been friction welded onto the turbine head.
What is also interesting is that Precision and TurboneticsINC both use this component in their turbochargers, in fact the shaft in this Precision turbo still has the Turbonetics logo cast into the back of the shaftwheel which an be seen in the pictures below."
