Head Parts help please.
  • HMS-S6
    • Jan 2010
    • 1164
    I'm finally getting round to putting the head back on my S6. I have the head gasket set but need bolts. I called GSF today and was told that they were dealer only. I don't want to cut corners at all but also don't want to be ripped off!! Does anyone know where i can get OE head bolts or a decent alternative?
    Also to be on the safe side i want to change the toother bottom pulley with the key in it, is this dealer only?
    Thanks for your help guys!!
  • europeanme
    • Oct 2005
    • 3817
    JP aka RWD19T might be the best man to help you there....
    • QuattroFever
      • May 2006
      • 1360
      volcano rs can supply a toughened pulley.
      Volcano ABY coupe
      Ant
      • merlin's S4
        • Jan 2005
        • 1539
        Pete @ quattro corner should be able to help with head bolts. Actually I may have a set here as I used ARPs in the end.
        • spink
          • 4382
          'payen' do the bolts for about £30 per set
          • HMS-S6
            • Jan 2010
            • 1164
            I can't find anyone who lists them mate!!
            • HMS-S6
              • Jan 2010
              • 1164
              Do you have any contact details for them please mate?
              • HMS-S6
                • Jan 2010
                • 1164
                If you have a new set a decent make, let me know your price dude!
                • JP
                  • 1858
                  Personally if not using ARP's I would only buy my headbolts from main dealer. Yes they cost almost triple the price but they are of a different quality and like an ARP rep once said the Audi headbolts are the strongest OEM going before upgrading to ARP's. Yet due to their sheer length if running high boost figures over 400ponies they're reliability is still hit and miss.
                  UrS6 Stroker + HTA3586 =
                  • Big Lee M
                    • 2571
                    Victor rienz head bolt from eemotorspares on eBay.(our lass's dads shop)
                    Just some finishing touches to do now
                    • HMS-S6
                      • Jan 2010
                      • 1164
                      Yeh i hear what you're saying, i think i'm going to opt for some ARP items. Do it once, do it right i think with this one!!
                      • HMS-S6
                        • Jan 2010
                        • 1164
                        I'm reading things about using different washers with them JP. Is this correct?
                        • JP
                          • 1858
                          The bigger the washer the bigger the spread of the clamping load the less it digs into the ally and the less you will have to re torque them
                          • QuattroFever
                            • May 2006
                            • 1360
                            That's his username on here. His name's Jamil IIRC.
                            Volcano ABY coupe
                            Ant
                            • HMS-S6
                              • Jan 2010
                              • 1164
                              Ok mate, that makes sense. Is there some washers from something else you recomend?
