rs2 turbo
  • bilko0795
    • Feb 2011
    • 1883
    rs2 turbo
    Hi guys can anyone tell me how to tell the diffrence between an Rs2 turbo and the S2 one and also are there any diffrences between the manifold,injectors,and the intercooler i believe the injectors are 330 ones im checking a car out with these mods just want to check iff that,s what it has, it is supposed to have 387hp it will be my first s2 iff i get it, so don,t know what sort of performance over a standred s2 i should expect it is a 3b engine, and is the aby a better engine.
  • david
    • Oct 2008
    • 1268
    rs2 k24 7200 turbo compressor housing and exhaust wheel are much bigger than s2 k24 7000.
    everything else is thesame.
    basically,rs2 stuff bolt straight onto s2 without any problem.
    just look for the turbo numbers above and you want go wrong
    aby is better than 3B
    [SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
    RS2 VOLCANO BLACK] soon to be broken to bits
      Rs2 turbo should have marked on the blue plate on the back of the compressor housing K24-7200 it's a larger turbo
      The exhaust manifold is different all runners collect at a central point, on the S2 runners 1 and 5 collect higher just below wastegate exit
      injectors are large and should be green topped if RS2 IIRC
      Intercooler is larger search forum for core sizes.
      3B engine uses a dizzy ABY coil packs
      • bilko0795
        • Feb 2011
        • 1883
        Rs2 turbo
        Cheers guys
