hi!
i have quite strange problem on my audi rs2. If i use stock ECU it works perfect.
Furthermore if i use chipped ECU from one tuner it works perfect to (caa max 1.8 boost). But if i use chip from other tuner with similar boost profil and target hp/nm there are some hesitation at WOT at 3th and higher gears at about 5200rpm. At those rpms boost drop to only 0,5bar but then raises again back. Timing is also retired back .......
Any ideas what should be wrong ?
ps: Booth chips are from good tuner.
