calling all turbo guru's
  • david
    • Oct 2008
    • 1268
    i've got a hair line crack about inch long in my turbo exhaust side and wonder if this will result in lost power or worst fall apart?
    i'm fearing the worst.
    [SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
    RS2 VOLCANO BLACK] soon to be broken to bits
  • AUDIS2avant
    • Jan 2009
    • 670
    • Country: Denmark
    Normal it Will not affect anything, but it depends ón how big and long the crack are.
    It Will affect spool up and top power if it leaks a lot.
    But hours looks fine tho.
    • nip
      • Apr 2006
      • 1786
      • Home: United Kingdom Current: Abu Dhabi
      probably worth getting better pics
      • david
        • Oct 2008
        • 1268
        3]probably worth getting better pics[/QUOTE]
        yeah i know,can only make do with what i got at the minute.
        the car still pull's very strong with no hesitation.
        • david
          • Oct 2008
          • 1268
          your right actually,it does not affect the power delivery much,but see hair line like that makes me worry abit.
          the turbo itself as minimal or no play at all.
          while this turbo is off for inspection i'm testing a rs2 k27 hybrid i put together a little earlier this year and will report back once finish testing.
          • my2000apb
            • Jul 2010
            • 637
            jstu have it welded with high nickel rod, ni99 i think and smooth it out with a sanding flapper wheel
            BEAST '90 CQ 24v VRT / O1E / v8 rear, HOLSET SUPER 40 http://www.theprojectpad.com/viewtop...1&t=193#p37887
            DD '86 4kq BLAZE, swapping aba/16vT and O1E http://www.theprojectpad.com/viewtop...1&t=201#p38264
            • david
              • Oct 2008
              • 1268
              i might just do that thanks.
              even though turbo works fine,i feel any little airline cracks will result in slight lose of power.so if it can be weld then it all good.
              • my2000apb
                • Jul 2010
                • 637
                yeah jsut make sure to clean the housing up so its smooth again
                not fixing the cracks will result in them getting much larger faster, just liek rust its best to fix it asap
