Whats the chances..30miles, No alternator..???
  • als2
    • Jul 2009
    • 809
    Alternator belt just let go on my 94 80 TDi. Im sure ive a spare at home and if not ive other cars there to go get one.
    So question is, will it run the 30 odd miles with no alternator????
    Super busy day at work, cant be 4rsed with this! lol
    Many thanks in advance guys
    AL
    Keep your lights, wipers and anything else heavy turned off like fans etc. 30 miles at ~30mph is one hour operation.
    Running the engine needs lets say 15A through ECU & such worst case, then maybe 10A for the fuel pump in the tank. So thats a 25Ah requirement.
    If you have a decent battery with even 60Ah capacity (stock S2 is much more like 90Ah) then you *SHOULD* be fine for that journey with plenty of margin.
    The only other advice I can give you is to get REALLY friendly with any stocking wearing ladies (or men) at work - a discarded stocking makes for a great emergency drivebelt
    • Nuvo
      • Nov 2003
      • 3825
      I doubt you'd be able to make thirty miles without the battery taking a charge. I wouldn't take the risk.
        30mins of engine running shouldnt drain a healthy 60Ah battery
        • Nuvo
          • Nov 2003
          • 3825
          The journey could be made, assuming the battery is in good health with a full charge to begin with.
          The jouney needs to be done with the minimum of delays too of course.
          I had to make a trip similar to this before when the brushes and slip rings were past their best.
          Even refraining from using all the larger power consumers as you suggest, it wasn't long before I was seeing the speedo gauge no longer work and the indicators fail and so on. But I still made it.
          So yes Al, you can certainly make the trip but just be aware of the pitfalls before you set out.
          • [RPM]
            • Dec 2009
            • 229
            • Home: Portugal Current: Ireland
            I will share the story of the day I bought my s2....
            I went to Armagh (North of Ireland)
            the car had a alternator problem
            so i made a deal with my E30 325i touring bought 2 60 Ah batteries in alffords
            and drove at night to Dublin 135km or 84mls with the lights turned off most of the time
            behind a truck
            the volt gauge was was always dropping and when it it a bit less than 8v the car just died.
            time to swap the batteries and continue the journey
            I think you will be ok
            • als2
              • Jul 2009
              • 809
              Hmmmmmmmmmmmmmm
              Lovin Pauls idea of befriending a stocking clad lady, altho i try that on a daily basis anyways! But alas ive asked and its a no!!
              Are we aware thats its a diesel, ie whats the implications on the glow plugs drain???
              Many thanks guys
              AL
                Glow plugs only activate on cold days until motor is up to temp... already seen its a diseasel... no sparks and presumably an ECU controlled mechanical pump so it looks OK to me - IF your battery is good...
                If your lady friend wont remove any garments for you, maybe she will lend you a battery ? LOL
                • spink
                  • 4382
                  Few years ago i bought a 20vcq from the west coast of the scottish highlands,was driving it back home(480 miles) when the alternator fell apart about 80 miles from home,managed to get onto my drive just as it cut out.With an 80 tdi not having an electric fuel pump you may find it could go a lot longer,but don't take my word for it
                  • S2Roo
                    • 191
                    This happened to me when I had an 80 tdi, I reckon it should be fine for that length of journey. However worth checking that when the alternator belt went it didn't snag the water pump belt/pully at all. Mine wound itself around the water pump, fortunately I was able to cut it off using a trusty leatherman and made my journey home.
                    • mcandmar
                      • Apr 2004
                      • 5118
                      I've done 60+ miles in the CQ20v with no alternator belt, at night too. By the time i got home i had candle light illumination, just enough for other people to see me basically, and a missfire under load but it made it. A diesel will go much further without the drain of an ignition system.
                      91CQ20v - Gone to a new home
                      93UR-S4 - The Magic Carpet
                      94S2Bus - The Emerald Express
                        No young lady at work who you can charm a set of tights off?
                        • als2
                          • Jul 2009
                          • 809
                          Rusty, i genuinely have asked them (well the ones i would ask if u know what i mean!) and alas, no! Stupid sun, they've all got bare legs today! lol
                          Fingers crossed itl make it home, not really a fix at work job either!!!!
                          hope i dont have to use the yellow card, thats just rubbish on a friday afternoon!!!! lol
                          A
                          • driftin jo
                            • Sep 2007
                            • 2222
                            Have a look in the petrol stations, some of them have emergency belts, if you haven't seen one they are like a piece of tube that you cut to length and join together.
                            like this one,
                            • als2
                              • Jul 2009
                              • 809
                              Oh that loks like a chewy sweet!!! lol
                              Cant see many BP Tesco etc having thos on their shelves!
                              Well nearly knocking off time so ill keep u posted if i get home or not!!
                              A
