start off with stipping the head down to the casting, ideally removing all the studs
buy some TFR
mix it 50-50 with water and spray it all over the head. scrub as much as you can then hit it with the jet wash. Repeat this until you get the worst the oil and dirt off.
get a container which is the same size as the cyl head (i made one out of stainless)
fill with a strong TFR-water solution
Leave the head to soak in the solution for a couple of hours
remove and jet wash again. rinse with plently of water and thats it. If you want to further improve the outside of the head you can get it vapour blasted or aqua blasted very quickly and easily.
IMPORTANT EDIT: do not remove valve guides for the cleaning process. TFR has corrosive properties on aluminium which can affect the clearances, meaning the new guides won't fit as tightly as they should.
buy some TFR
