need a second opinion
  • [RPM]
    • Dec 2009
    • 229
    • Home: Portugal Current: Ireland
    hi all
    I'm going to put new forged rod in my engine (aby)
    its 220k miles
    would I get away with honing and new piston rings?
    there is no smoke and the exhaust tips does not show any grease.
    starts normally in the Irish winter
    and pulls well quoting forum member mcandmar
    thank you
  • K Simmonds
    • Dec 2007
    • 7627
    Test compression before you take the head off then check the bores for signs of wear once it's off. If all is well then a rebore is not required, low compression could also be caused by poorly seating valves so base you decsion on the state of the bores. But do the comp test anyway as it's very simple and could highlight a problem cylinder.
    I recently took the head off a 230K mile 6A 2.0 16V engine that's going into a MK II Golf GTi. I was expecting some bore wear, however all the bores are perfect, no signs of wear whatsoever. I didn't bother doing a comp check on that as I was expecting to be reboring.
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    • [RPM]
      • Dec 2009
      • 229
      thank you
      I don't want to get crazy with cash so if i can get away with a hone
      recession times
        Measure first to be completEly sure. You can do that across bore and by checking gaps on the rings.
        • K Simmonds
          • Dec 2007
          • 7627
          Indeed, when I said check bores I ment with a vernier caliper as well as by eye.
          1994 MTM RS2.
          2000 B5 TQS.
          • [RPM]
            • Dec 2009
            • 229
            will do
            thank you all
