mrs new ( to us) tdi Sharan playing silly ******s on hols!
Steepest hill we needed to pass in Wales n the thing died on me doing 70 in the fast lane.
rev counter stuck at 1100rpm, depress pedal and nowt happens so switch off and starts and runs ok now
put on vag com when we got back and says pedal sensor sporadic fault so...
how to change it?
is it just remove and refit or do i need to re vag it to set it up?
think i ll change th emaf at same time as its a bit limp and came up with a fault too, good job car was cheap
how to change it?
