I took the RS2 out for it's maiden 'proper' drive this evening
The car feels great driving it around 2-3.5k rpm, it starts to run rough approaching idle and you get some popping from the exhaust. On idle it hunts 800-1000rpm with a constant slight popping - like a slight miss, but not on any particular cylinder. It stalls intermittently backing off to idle - hot or cold - and takes 10-15s after starting for the idle to rise from a lumpy 5-600rpm up to ~900rpm.
After a good drive to bed in piston rings I pulled codes and got 2341.
Any ideas? If it was consistent I'd have suspected unmetered air, if the MAF was knackered could it cause this code? The missing made me think bad earth on the coilpacks, again this seems good and it smooths out as soon as the revs rise. Not quite sure where I should start.
would make sense too as its been starting rough lately too.
