Hi,
My 3b is giving me massive headaches. The trouble is idling, and the occational stalling when coming down from higher rpms. My typical idle is around 500rpm cold/warm.
I looked around too see if I could find any air/vacuum leaks, and tightened some loose clamps in the breather system. This seemed to help with the stalling, but did nothing with the idle.
Stange thing is that this happened before too, when the car had a 7A in it. Leads me to think either fuel pump/reg or some part of vacuum system that wasnt switched.
No fault codes.
Ideas?
No fault codes.
Ideas?
