Schrick Cams on AAN.
  • popdemonic
    • Dec 2007
    • 1304
    • Country: Thailand
    Recently ,I just received the Schrick Cams for AAN motor.
    Intake;
    opening duration 260° (to be used with hydr.Tappets)
    peak angle 112°
    cam lift max.: 10.9mm
    lift at TDC: 0.8mm
    Exhaust;
    peak angle 112°
    lift at TDC: 0.9mm
    The car currently the GT2871 with 034 software.what would i expect any gains on this cams?The problem is I found there's no timing marks on the cam gears.
    what's the easiest way to get it done on my head?Do i need the dial gauge,timing light
    to verify it?
    one of a few I5 from Asia.
  • terrybullwon
    • Mar 2006
    • 8782
    are they new?
    Chef
