Best street setup with stock rods!
  • shone190
    • Oct 2006
    • 527
    • Country: Serbia
    What do you think about buying RS2 turbo, injectors and "contact" them: http://chips-ur-s.com/Entrance.html for Stage 3 setup
    "Stage 3. This level of performance enhancement is usually referred to as an "RS2 mod". Our Stage 3 mod uses the same VMAP (or Bosch PT if available) as Stage 2 but software is provided to accommodate higher flow RS2 level turbos and higher flow injectors to accompany those turbos. Maximum boost levels of 26-28 psig are available. Performance is improved to the 360 to 380 hp level. This, of course, requires the addition of an RS2 turbo, exhaust manifold, and higher flow injectors."
    Is this really possible to get without "realtime" tuning?
    Audi URquattro 4.2l, Dodge Charger 7.3l, Golf 4 TDI 4Motion
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      yes of course¡¡ but more like 360Hp ,more than enough
      • shone190
        • Oct 2006
        • 527
        • Country: Serbia
        You are my man
        If it's possible, "only" that I need now is money
        • A80Avant
          • Sep 2005
          • 10873
          • Country: Greece
          i suppose there is nothing wrong in getting a specific package, as it happens with many new audi's and companies, so long as you are able to know that they are trustworthy and you get excactly as the package recommends. I wouldnt go that way, as im more for the live mapping, each car is slightly different, but if it is going to cost you much more to get a tuner in your country for the tune, then its the best alternative
          • shone190
            • Oct 2006
            • 527
            • Country: Serbia
            #20
            If I can expect about 350HP with RS2 setup without live mapping with MRC chips, this is enough for me
              Get a hoffer76 or MRC high boost chip 360 bhp bobs your uncle
              • DamianURS4
                • May 2010
                • 406
                i have had the 034 package, i have had a lot of things, but the chips never delivered what i hoped for, and my car stopped accelerating at 150-ish not impressed. There was good economy from the injectors but that wasn't what i was after. There are many folks on this site running stock internals, a hot turbo and some interesting chips. Most of these folks additionally employ some or all of the following: bigger downpipe and exhaust, after market exhaust manifold and injectors plus more. i would personally put in a word for Hoffer's set ups, he can provide turbo, injectors and a mapped ecu if needed with some good site references, or alternately he can provide you some tried and tested chips but you would have to sort that out with him. He is in Portugal for a week, but I wouldn't rule him out.
                Hope that helps.
                • shone190
                  • Oct 2006
                  • 527
                  • Country: Serbia
                  #23
                  I suppose You think their chip with RS2 turbo?
                  Is it necessary to mount RS2 EM or stock S2 3B is enough?
                  • DamianURS4
                    • May 2010
                    • 406
                    when you say 'their' i guess you mean MRC or Hoffer - if I am correct then go down the route of rs2 if you can afford for increased throughput and better flow characteristics. injectors are a must, and you will need to verify your FPR is adequate.
                    • shone190
                      • Oct 2006
                      • 527
                      • Country: Serbia
                      #25
                      Yes I mean MRC or Hoffer
                        To go RS2 K24-7200 or larger (vs stock K24-7000) it is wise if not manditory to upgrade the EM to OE RS2 or Wagner RS2 EVO. Otherwise, you risk burning the exhaust valves on 1 and 5 because of the stock 3B/AAN/ABY EM design.
                          I am running full RS2 hardware (Exhaust cam, EM, turbo, MAF, injectors) and MRC Stage 3 "generic" (i.e. not tuned on my specific car) software. Have done 288 whp on a Dynajet rolling road. (Same day somebody with Dahlback/MTM and similar hardware s/w did 293 whp). Mine is considered to be about 360 crankhp. So yes, it works.
                          Chips-ur-S is MRC's rep in North America. Bob Myers runs it and is a good guy.
                          • shone190
                            • Oct 2006
                            • 527
                            • Country: Serbia
                            #28
                            Thanks a lot
