missing a crank pulley washer i believe...?
  • euro_urs4
    • Nov 2008
    • 267
    • Home: Poland Current: United States
    hey guys i was trying to crank over my motor finally and found that the crank pulley is hitting the block slightly, and im assuming im missing a washer somewhere between the crank pulley, and the pulley holding the timing belt.. anyone ever run into this or drop the washer, which washer could it be that im missing, and when you look from the top of the motor, the timing belt is super close to the engine so im guessing there might be a washer on the timing belt pulley., heres a diagram of it
    i wanna say i need number 2, but that doesnt show anything of a washer, thanks for the help in advance guys
    Did you, by chance, install a new crank damper pulley (the one with the rubber centre)?
    This is what I am talking about (related to item 3, the 251J damper):
    • euro_urs4
      • Nov 2008
      • 267
      not that i would know of, possibly the machince shop. why would that push it back?
        For some reason the newer style 251J damper (replacement for the 251H) requires a spacer washer to move things out and away from the oil pump.
        • blackS2
          • Apr 2010
          • 455
          The washer ist not number 2. it's not shown in the AKTE picture...
          it's named diamond coated washer - approx. 30€ - it's a friction washer
          the damper to use with the washer is a little bit shorter on the backside than the other one...
          for the other one, with the longer end, you can use the diamond coated washer from RS4 (0.1mm)
          my old one:
          my new one:
          [__]=oooo=[__]
            Item 2 is the cam that drives the oil pump, as I thought I had said on quattroworld.
              Originally posted by blackS2
              the damper to use with the washer is a little bit shorter on the backside than the other one... for the other one, with the longer end, you can use the diamond coated washer from RS4 (0.1mm)
              Are you using the newer 251J Damper and therefore need the 034105193 washer?
              • blackS2
                • Apr 2010
                • 455
                I don't know the number on my damper... the damper is still the original part on my 94 ABY and it had the washer from factory...
                [__]=oooo=[__]
                  Why is your oil pump made in KOREA, not Germany?
                  Here is a German made one. (Exploded photo from somebody on here, annotated by me)
                  • blackS2
                    • Apr 2010
                    • 455
                    all oilpumps delivered here by audi dealer are made in korea now but still original Audi...
                    [__]=oooo=[__]
                      North Korea? Someone call Team America World Police!
                      • euro_urs4
                        • Nov 2008
                        • 267
                        Yeah I'll have to contact the builder and see which dampener they used buy i def need the washer, so just getting this straight the rs4 washer will work, anyone have a part number on that? And then this washer goes after the oil pump and before the timing belt pulley
                        my old one:
                        my new one:
                        • mcandmar
                          • Apr 2004
                          • 5118
                          For an ABY/ADU you need the washer 034105193
                          91CQ20v - Gone to a new home
                          93UR-S4 - The Magic Carpet
                          94S2Bus - The Emerald Express
                          • blackS2
                            • Apr 2010
                            • 455
                            yes of course (3mm thick)
                            the washer is between the timing belt pulley and the damper NOT betwee the oil pump and the timing belt pulley
                            oilpump - timing belt pulley - washer 034105193 - damper
                            the washer belongs to the surface of the crankshaft end right at the tip of the red arrow... on the picture, the washer is not in place yet...
                            [__]=oooo=[__]
                            • euro_urs4
                              • Nov 2008
                              • 267
                              Is that the same part number for the aan motors i'n te urs4?
