missing a crank pulley washer i believe...?
  • blackS2
    • Apr 2010
    • 455
    Originally posted by euro_urs4
    Is that the same part number for the aan motors i'n te urs4?
    yes...
    somtimes it happens in this way:
    you allways have to change the pulley if you change the belt...
    the washer is stuck in the pulley and thrown away with the old pulley without notice that...
    and after assembling the new pulley - oops something is different...
    but the last US4 I disassembled, had no washer... surprise surprise... so watch out ;-)
    [__]=oooo=[__]
    • euro_urs4
      • Nov 2008
      • 267
      • Home: Poland Current: United States
      Another quick question that washer then makes it's flush with the timing belt pulley? Since without it there is a slight indent i'n the pulley?
      • euro_urs4
        • Nov 2008
        • 267
        im reusing the old pulley, and i possibly could have dropped the washer or it possibly didnt come with one :/ so, the only reason why its hitting could be the fact the a differ damper was installed? or a lost washer, it doesnt have anything to do with the oil pump, or those rings etc inside of there
        Originally posted by blackS2
        yes...
