Turbobandit
  • [RPM]
    • Dec 2009
    • 229
    • Home: Portugal Current: Ireland
    Turbobandit
    any info or feedback on this turbos?
    they have some funny videos on youtube...
    and they say its not China turbos
    for ex:
    Ideal for cars that can not use twinscroll such as 5cyl Audis and even later BMW 24v engines due to steeply angled motors elimintating the possibility of a twin entry turbo manifold configuration Recommended for 500-650hp vehicles......623EUR
    Compressor housing
    0,60 A/R
    Inducer 60,5 mm
    Exducer 84 mm
    TRIM 51
    Inlet 102 mm
    Outlet 2.5”
    360 bearing
    Turbine housing
    0,70 A/R
    T4 undivided flange
    Exducer (outlet) 65 mm
    Inducer 75 mm
    Outlet 3" V-band
    Oilcooled only
    Incl: V-band flange and gaskets
  • Thuppu
    • 4115
    Many use divided housings with I5 engines and they work perfectly fine.
    • [RPM]
      • Dec 2009
      • 229
      That one is t4 flange. Non divided
      Anybody knows them or know somebody that uses their turbos?
      • Thuppu
        • 4115
        Yeah, I know, but the text says "ideal for cars that can't use twinscroll turbos". On a I5 engine you can use twinscroll(divided turbine housing) without problems. You only not get the benefit of the twinscroll housing geometry because you can't use a divided puls exhaust manifold.
        • [RPM]
          • Dec 2009
          • 229
          I would thought that a twin scroll or divided flange would work better on a even cylinder engine 4 or 6
          probably that's what he is referring to in the case of the i5
          • prj
            • Mar 2010
            • 6308
            I don't see any links...
            Why not take something that is proven?
            Such as a HX35 Super for 770 euros
            • [RPM]
              • Dec 2009
              • 229
              • dspl1236
                • Feb 2008
                • 242
                sometimes different is nice...
                ...and sometimes different will bite you in the ***
                I am always for what no one else does
                '91 Pearl 3.6 V8 CQ - building
                '13.5 Jetta GLI - toy
                '15 Subaru Imprezzzza - work daily
                hausofdub.com
                • maniac
                  • 119
                  Here two videos with a S2 with a Turbobandit turbo and other stuff.
                  727hk/750Nm @ 2.6bar
                  Audi S2 turbobanditen, Ny WG-fjäder med grundladd på 1,5 bar.
                  And a link with some info about the car (swedish only ): http://www.garaget.org/?car=172197
                  S2 Avant -95
                  • prj
                    • Mar 2010
                    • 6308
                    Says absolutely nothing about the turbos though.
                    I doubt the guys make their own, so what parts do they use? Garrett?
                    If the question is the price - a HX35 will easily provide you with upto 470hp for 690 EUR.
                    HX35 Super is 790 EUR.
                    KKK K26/K27 hybrids can be had for 580 or so I think...
                    • [RPM]
                      • Dec 2009
                      • 229
                      i'm always open to new ideas
                      • vajdan
                        • 8
                        It's a lot of audi i5 turbos here in Sweden who drives with turbobandit turbos, and it works fine,. Over 2,5 bar boost for multiple seasons.. I think they are a better option than the holset turbos. I know no one who has had problems with them.
                        • quattro84
                          • Mar 2006
                          • 947
                          The T3 non-divided turbine housing looks like a copy Garrett casting. Casting roughness is different though.
                          Look at the shape of the inlet, both scrolls aren't alike and i don't like the dents neither.
                          T60 line-up all use 76/65mm 12 blade turbines just like the HX40.
                          The CHRA looks familiair but i don't know what make it is, No Holset AFAIK.
                          The spherical bearing design is something i've have never seen before:
                          I do know i wouldn't piss of that Russian owner Roman, that guy is completely insane http://www.youtube.com/watch?v=QP5CtDmTIpc
                          • quattro84
                            • Mar 2006
                            • 947
                            Whoopsie forgot about mentioning part II: http://www.youtube.com/watch?v=C4APY...eature=related
                            So, fine turbo's.. good pricing.. no China parts, only quality Turrrbinaaa judgeing by these fine pieces of footage.
                            • [RPM]
                              • Dec 2009
                              • 229
                              he is mental
