Suddenly one cylinder down.
History - bought the car in May - 1994 ABY - 235000km, samco hoses, RS2 exh. manifold, 3" downpipe and exhaust, metalcat, Ultimot chip. Coils and injectors original I believe. 265hp in june.
VAG COM 409.something gives some 561 fuel adaptation (both too low and too high) (from memory) - definately no errors on coils or injectors. Output test - no sounds from any of the injectors. Other outputs OK.
Please kick me in the right direction - How do I test individial coils? The injectors - do I just disconnect and measure the plugs one by one with the engine running?
Thanks in advance
EDIT : one POS channel (#2) was down on the one driving 2 coils - switched the green wire from terminal #3 to #1 in the input plug, and the corresponding black wire from #2 to #3 in the output plug.
The best rides are the test rides when a repair is finished
Thank you very much Merlin, prj and also UrS4Boy and Mr. Nugent for the detailed info provided. Beers all around
:mischeif:
Thanks in advance
:mischeif:
