K24 part numbers
  • PiterS2
    • Nov 2009
    • 155
    • Home: Denmark
    K24 part numbers
    problem solved
    Originally posted by PiterS2
    Hi. I have a question. I can see there are a few k24 part numbers. Do they produce the same hp? 034145703 C = 220hp? Thanks /PiterS2
    Not sure where you got that part number since 034145702 is the number that ETKA recognizes, not 703C.
    Regardless, the K24-7000, i.e. the stock 3B, AAN, and ABY turbo is good for about 280 hp with the right chip set and 3 Bar manifold absolute pressure (MAP) sensor. People have pushed the K24-7000 above that, e.g. 300 hp, but at that point, you are running outside the normal efficiency boundaries and producing a lot of extra and unwanted heat. Sure way to kill the turbo sooner than later.
    • PiterS2
      • Nov 2009
      • 155
      • Home: Denmark
      Okay, It's because that part number is on the turbo and im not sure it the right one.
      • javispa
        • Jul 2007
        • 292
        • Country: Spain
        That part number is from an Audi 200 turbo, 165 hp. You can check most of the KKK turbo part numbers here:
        Cheers.
        Audi Coupé S2 '92 -- VW Golf 2 GTI '91 (v2) -- Renault 4 TL '84 -- Audi 100 2,3E '92 (Dad's) -- Suzuki SV 650 S '08
