Hello all,
First start up of my engine after a prolonged down time + slight rebuild resulted in a strange noise (a tapping, or almost a pinging noise) and high oil pressure on gauge (past 5 bar) with the blinking/beeping red oil light on the dash. Car laboured to start up and the idle was low/rough.
Oil gauge only pegs far right after the car starts up, not when the key is on and motor not running.
Quick summary of work done:
- OEM (re-manufactured) power steering rack (edit: rack, not pump!)
- OEM crank pulley cog & harmonic balancer
- OEM flywheel and clutch bolts
- OEM gaskets (head/valve cover/exhaust/rear main seal)
- OEM distributor rotor & cap
- 034 spark plug wires
- 034 timing belt kit w/ water pump & thermostat
- 034 silicon rad hoses & aux. rad delete
- 034 street density motor & trans mounts
- 034 snub mount & bracket
- 034 phenolic IM spacer & gaskets
- 034 7A EFI upgrade kit w/ resistors
- ARP headstuds
I didn't touch the oil pump at all, other that to remove the oil temp sensor wire.
Any ideas would be greatly appreciated. My best guesses so far would be: faulty oil pump, backwards/stuck oil pressure relief valve, crossed connections at the oil pressure sensor, faulty oil pressure sensor.
Here's a quick list of links I've found so far on my search for possible solutions:
link 1
link 2
link 3
link 4
- ARP headstuds
link 1
link 2
link 3
link 4
