Cylinder head coolant ring
  • SteveH
    • 4460
    The Audi works cars ran this mod. The gains in cooling allow you to be more aggressive with timing as Jamo mentions. You can get the machining done for £150 if you look around. Doing the head and block would be a good idea, but it does mean ripping the engine out and dismantling to achieve this.
    I have an unused 3B block that is screaming to have this done.
    91 Modded 3B
    14 A6 Avant Black Edition
      Yeah I first heard of this AFTER I finished building my car 6 months later
      I suppose it all depends how you want to go and if I'm prepared to take it all apart again, undecided
      • Billman
        • 4129
        I think it a nice feature if you are going to remove the head and wanna run things to the limit. Personally would not remove the head but I would make it to the spare one.
        It a nice add on and one can use this without any disadvantages.
        Go Holset or Go RS4
        • Thuppu
          • 4115
          Originally posted by terrybullwon
          And it's a water jacket
          How deep and wide should the groove be? Is 5x5mm enough? Does it work good enough on the head only, or should it be on the block also?
