What else cause 0.4-0.5 bar max boost
  • Rusty
    • 18953
    What does VAG com say the atmospheric pressure is?
    • shone190
      • Oct 2006
      • 527
      • Country: Serbia
      #92
      I am not that familiar with Vagcom, where I can see that, if it's not too complicated to tell?
      Audi URquattro 4.2l, Dodge Charger 7.3l, Golf 4 TDI 4Motion
        F96 Altitude/Barometric Pressure Sensor Information
        You might want to check the connection to the F96 Atmospheric Pressure Sensor in the Urq. The AAN ECU wants a signal from it. With no signal, the controlled boost is reduced to zero, i.e. mechanical boost (which is all you are getting).
        Here is some F96 info:
        • shone190
          • Oct 2006
          • 527
          • Country: Serbia
          #94
          Thanks UrS4boy, I'll check it today later, after work and inform You
          • shone190
            • Oct 2006
            • 527
            • Country: Serbia
            #95
            Originally posted by prj
            I mean, if you get 1.5, ok let off.
            But if all you get is 0.8 bar then something else is wrong.
            OK guys, that's the situation I'll put manual boost gauge in car, disconnect the hose from N75 to WG and try the car again. There is no chance that I get boost greater than 1.3 bar, so definitely something mechanical is wrong
            Do You have some ideas what to check now?
              DO NOT DISCONNECT the hose between the N75 and the WG. DO that and there is NO control over the WG period. Just disconnect the electrical connection to the N75 and do your testing.
              • shone190
                • Oct 2006
                • 527
                • Country: Serbia
                #97
                Without electrical connection I got only 0.4 bar as I should, mechanical boost.
                This is definitely not normal at all that I can't get boost more than 1.3bar without N75-WG hose.
                • shone190
                  • Oct 2006
                  • 527
                  • Country: Serbia
                  #98
                  Does anybody know what can cause only 1.3bar of pressure without WG hose???
                  It means that there is no way at all that I can imagine boost pressure more than 1.3bar ever, with any kind of chip, MAP...
                  • prj
                    • Mar 2010
                    • 6308
                    Dump valve, blown check valve under manifold, incorrect cam timing.
                    • shone190
                      • Oct 2006
                      • 527
                      • Country: Serbia
                      #100
                      I changed dump valve, so this is not problem, cam timing also can't be a problem, because everything work OK until some day
                      What do You mean by "check valve under manifold"??
                      • prj
                        • Mar 2010
                        • 6308
                        Check valve for breather system for manifold source. EVAP joins there as well. Plug that pipe on both ends and try.
                        Also timing can be a problem if belt slipped a tooth etc...
                        • shone190
                          • Oct 2006
                          • 527
                          • Country: Serbia
                          #102
                          Thanks for directives, I'll try it and check timing cam too
                            #103
                            Just read this thread because I have an intermittent boost problem.
                            @ Shone190, what ever happened ?
                            Did you ever find a cure, or just burn it in disgust ?
                            Thanks.
                            • shone190
                              • Oct 2006
                              • 527
                              • Country: Serbia
                              #104
                              Hi, no I never find what was wrong and now there is AHC 4.2l V8 engine in UR, I no longer have nerves to fight with problematic I5 turbo engines
                                #105
                                Thanks for update. Is the V8 ok, or does that bring it's own set of issues ?
