turbo oil lines gaskets
  • K7ERG
    • 1711
    Since I am in the process of changing turbo on my 5 pit diesel I am looking for the best option when installing the oil lines.
    New gaskets on there own?
    Or
    A little sealant on both sides of the new gaskets
    Or any other recommendations to save leakage.
    Craig
    Audi A6 AEL 5cyl Quattro breaking.
    Audi A5 3.0tdi Quattro Stage 2
    07947385043
  • Dobby84
    • Feb 2011
    • 1169
    When I changed my turbo a while back I bought some gasket paper from my local parts shop as a quick fix. I didnt bother using any paste as I heard that if any of the paste got into the oil it could cause problems.
    I later replaced the paper gaskets with propper ones that I bought from Quattro Corner but Im not sure if Peter can supply ones for an oil burner or if he only specializes in quattros. Maybe worth a phonecall.
    Hope this helps in some way.
    Simon
    • K7ERG
      • 1711
      I tried Pete he said he doesn't do them. The turbo is a k24 from s2. I have since bought new gaskets from audi. I was thinking very little gasket sealant around the edge of gasket away from the oil hole.
      Just getting everything ready.
      07947385043
      • Dobby84
        • Feb 2011
        • 1169
        I was just taking advice from others regarding the paste. Mine havent leaked since I changed them without using paste. I just made sure that all surfaces were clean and free of any dirt/grim.
        • Thuppu
          • 4115
          I also made new oil line gaskets of gasket paper. I didn't use paste and no leaks so far.
          • Ross
            • Aug 2005
            • 3399
            I've heard of small bits of silicone paste being removed from a failed turbo... would steer clear if I were you.
            Having replaced the oil feed gasket 3 times in the past couple of months I can tell you:
            • The bits are cheap from Audi, cost me £4 for a 2x new gaskets, studs and nuts
            • Get a very clean surface - use a blade to clean it - on the oil lines
            • Most likely to leak is the inlet as that's where the pressure is
            • It may weep oil the first few runs, but it'll bake very quickly and seal
            • Nuts are rated to 10nm but I used 14-15nm to get a good seal. 18-20nm is too much, you'll end up replacing the studs, trust me!
            • Put the oil line on before the water line
            • Also replace the copper rings between the turbo and water line fixings
            • K7ERG
              • 1711
              Thanks for the info. Will get time tonight to.hopefully get running with the k24. Just hope its better than with the vnt setup.
              07947385043
