what the hell is this
  • bilko0795
    • Feb 2011
    • 1883
    Hi guys while i had the car up on the ramp today i found this stuck in the front subframe anyone know what it is .
    Ray.
  • pixsaudisex2
    • Sep 2004
    • 3110
    fits on inlet throttle damper thingy.. look at the thread pictures of engines.
      Originally posted by bilko0795
      Hi guys while i had the car up on the ramp today i found this stuck in the front subframe anyone know what it is . Cheers Ray
      Throttle body dashpot damper (slows the closing of the throttle on complete lift off the gas pedal) and bracket.
      Item 2 here (for an AAN, but also on 3B, ABY and ADU):
      • RS2junkie
        • Mar 2011
        • 409
        • Home: Ireland Current: Bahrain
        its a throttle damper, as on s2 or RS2 and possibly others. Stops the revs dropping to idle during gear changes....
        works on the throttle cable on top of the throttle housing...
        Paul
        • driftin jo
          • Sep 2007
          • 2222
          you can see it in the bottom pic in link.
            As in this?
            • bilko0795
              • Feb 2011
              • 1883
              Thanks guys just had a look at the engine and seen where it goes can,t think why it would be taken off i take it that i best refit it.
              • Fat Audi 80
                • 10547
                I bet the previous owner spent bloody ages looking for that!
                The Perfectionist
                • Rikki Kitto
                  • Feb 2010
                  • 6276
                  What on earth was it doing down there?
                  • Fat Audi 80
                    • 10547
                    It was probably taken off to again access to the spark plugs under the coilpack cover....
                    The Perfectionist
                    • bilko0795
                      • Feb 2011
                      • 1883
                      I don,t think the last owner new it was missing but like you said it could be from changing a coil pack he had done in july 09 so it shows you that it could of been off that long , the car has only done 4000miles since july 09 until now i have just done 780miles bringing it from aberdeen to south wales, not knowing these cars i wouldn,t know how the car performs but i will refit it tomorrow.
                      • benntenn67
                        • Jun 2009
                        • 859
                        If you don't want it I'll have it, as mine is missing - still drives ok without though
                        Audi S2 Coupe 1995
                        VW Passat GL5 (hatch) 1986
                        VW Passat GL 1.8 (saloon) 1986
                        Carrera Subway 8
                        • johne
                          • Apr 2007
                          • 1404
                          I don't believe you'll notice the difference with it back on. My car, one of the last coupes, never had one fitted from new.
                          I've never been able to confirm if the Motronic S/W was changed to compensate - since what this item does mechanically Motronic could choose to do under its software - but I now run fine on Paul's Homefries S/W.
                          In 155,000 miles driving my car has only stalled once after lifting my foot off the accelerator
                          John
