I have just repeated this from my project thread to help get some responses as I'm getting to my wits end!
I have been having problems with my rad hoses pressurising so last night I drained the coolant out of the system. I removed the thermostat and checked that it was opening up as it should and not stuck shut. It works fine so put it back in.
Made sure the fan plug was in correctly when I put the rad back in. Bleed the system as per Rusty's http://http://www.s2forum.com/forum/...light=bleeding thread.
Everything was going well as I warmed the car up, Thermostat opened up fine, then suddenly the pressure in the top and bottom rad hose shot up.
They were pretty much rock solid. The temp gauge was reading around 90+2 lines. but the rad fan didnt cut in.
Im very concerned that my head gasket may have gone but fingers crossed its something else as its almost brand new and only done a few miles since it was replaced.
There was a fair bit of steam exiting the exhaust though but was hoping that is just condensation as the car hasnt been started for about a month.
Does anyone have and ideas what I can do next before looking into the head gasket?
Does anyone local (buckinghamshire) have a compression test kit or leak down test to check the gasket?
they can behave strangely for a while until fully bled. Check that you have a functioning thermo switch so the fan can kick in, in my experience these can crud up a bit on the connectors and stop it working, get a length of heavy guage wire and jump the terminals to check that the fan will run, then you are down to checking relays, the actual electric circuit or even a fried fan (had this myself)
