What 4 bar fpr to use
  • dich
    • Apr 2010
    • 52
    • Country: Bulgaria
    Is there any difference between 1.8 t fpr and 7a one.Both are rated at 4 bar.I want to replace my 3b 3 bar fpr with 4 bar one.But I can t find a 7a one.Will the 1.8t fit on the fuel rail.
    Fuel Pressure Regulator info and PNs
    I am guessing that the 1.8t FPR is a clamp-in with an O-ring. (but I could be wrong) Your 3B needs a bolt in. Link to more info below this table:
    7A, 20V NA, 4.0 Bar nominal, bolt in = PN 054133534
    3B, 20VT, 3.0 Bar nominal, bolt in = PN 034133534M
    AAN, 20VT, 4.0 Bar, clamp in to VIN P080000 = PN 078133534A (UrS4, Bosch 0280160516) (Clamp PN N10210602)
    AAN, 20VT, 4.0 Bar, clip in after VIN P080001 = PN 078133534A (UrS4, Bosch 0280160516) (Clip PN 037133047A)
    AAN, 20VT, 4.0 Bar, clip in = PN 078133534C (UrS6, Bosch 0280160517) (Clip PN 037133047A)
    ABY, 20VT, 4.0 Bar, clip in = PN 078133534C (same as AAN) (Clip PN 037133047A)
    RS2, 20VT, 3.8 Bar, clip in = PN 034133534P (Clip PN 037133047A)
    More info here: http://forums.quattroworld.com/s4s6/msgs/21108.phtm
    • mcandmar
      • Apr 2004
      • 5118
      Any 1.8t's i have seen were the clamp in type, i.e. same as AAN/ABY
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
      • rs200
        • May 2009
        • 1398
        • Home: Croatia
        i use 4.0BAR FPR from audi 2.8 v6 , I cut 2.8 fuel rail and weld it on one fuel line which go to fuel rail .
        other side of FPR are plug n play into 3b pipe
        • prj
          • Mar 2010
          • 6308
          Isn't 7A 4.2?
          • rs200
            • May 2009
            • 1398
            • Home: Croatia
            Originally posted by prj
            Isn't 7A 4.2?
            yes they are..
            most easy way to fix 4bar FPR on 3B engine is to use 2.8 v6 FPR .
            there is lot of 4.0bar FPR in VAG group . and I think that 4.0bar FPR are all the same.
            • dkw_dude
              • 555
              • Country: Norway
              I have an adjustable 3B FPR, built with a conversion kit from a Finnish company some years ago. Works good and a nice kit. It's not for sale, but I can't remember the name of the company, maybe someone here knows it?
              Leif-Helge
              -91 S2 VEMS and Comp Turbo
              -12 B** 530XD Touring "S2 parts transporter, and daily driver"
              • Rocco
                • Aug 2007
                • 6393
                • Country: Spain
                I fitted a new 7a FPR in my 3b engine,perfectly without any problems
                • Thuppu
                  • 4115
                  AMWorks?
                  • sam80quattro
                    • Oct 2006
                    • 1496
                    ive got 1 kicking about in my shed somewhere.. 7a fpr that is £10 plus postage...
                    • SteveH
                      • 4460
                      The main benefit of the 7A FPR in the 3B is that it's a simple bolt-in replacement and it's cheap.
                      91 Modded 3B
                      14 A6 Avant Black Edition
                      • dkw_dude
                        • 555
                        • Country: Norway
                        Originally posted by Thuppu
                        Yes! Thanks Thuppu!
                        Leif-Helge
