oil pressure
  • bilko0795
    • Feb 2011
    • 1883
    oil pressure
    The oil pressure is showing 5 bar on the gauge is this normal??????
  • rs200
    • May 2009
    • 1398
    • Home: Croatia
    it is normal if the engine is cold.. after few minutes it have to drop on 1.5 - 2 bar.
    • s2driveruk
      • 12696
      At idle cold or whilst driving 5bar is perfectly normal...o
      1992 3b S2 Coupe
      • bilko0795
        • Feb 2011
        • 1883
        Thanks guys it is 5 bar at idle
        • Billman
          • 4129
          Warm idle 5 bars?
          Go Holset or Go RS4
          • irishs2
            • Apr 2009
            • 2455
            When the one of the wire contacts from the oil pressure gauge sender on my car was corroded it showed a permanent >5bar. I just cleaned the contact and refitted the wire and back to showing 2bar ish when warm.
            Eric
            95 S2 Avant under rebuild.
            • bilko0795
              • Feb 2011
              • 1883
              No cold idle
              • Billman
                • 4129
                Cold idle is normal at 5 bar?
                What is the pressure at warm idle?
                Go Holset or Go RS4
