Engine power at 0.5 bar
  • Billman
    • 4129
    can't really see how to use this tool. I had 34% DC with an AFR of 13 at 0.45 bar.
    Don't know if I did it right but I came with 190hp.
    Go Holset or Go RS4
    • rst
      • May 2006
      • 102
      What size injectors you have and whats the fuel pressure?
      Audi UrS4 609hp/846Nm @ wheels
      10.911@210, 1km 268km/h, 1mile 295km/h
      FATS 2,30 sec
      • Ross
        • Aug 2005
        • 3399
        I've found the turbo comparison calculator on 034 website works pretty well if you use JP's VE figures.
        034 Turbo calculator
        Using figures I played with for my engine I get around 200hp @ 6500rpm @0.45bar (AFR 12.0), up stroke to 92.8 and that gives 215hp. I am assuming a slight VE increase for my head work, using stock figures is about 15HP lower... so 200HP seems about right.
        • prj
          • Mar 2010
          • 6308
          IDC indeed tells a few things...
          However, with meth, you would make 20% more power with lower IDC for example.
          Same goes for dropped CR and higher octane fuel.
          • Billman
            • 4129
            #20
            630cc at 3 bar. I run 3.8 bar FPR.
            Go Holset or Go RS4
            • rst
              • May 2006
              • 102
              You made the calculations right. It is about 190 astonishing horses under the hood with that setup.
              FATS 2,30 sec
              • Billman
                • 4129
                #22
                uuhhhh yeah. not bad for 6000 RPM at 0.5 bar where it is almost completely out of the compressor map....
                Go Holset or Go RS4
