Snub mount info?
  • ThatGUY
    • Sep 2004
    • 794
    Snub mount info?
    I'm after the part number for the snub mount. The part that bolts to the block.
    Thanx,
    Andrew
    //-\\ ((_)) //)) //
    Originally posted by ThatGUY
    I'm after the part number for the snub mount. The part that bolts to the block. Thanx, Andrew
    Where are you in Washington State? Burien mean anything to you?
    For an AAN the items you want are 17 and 18:
    • ThatGUY
      • Sep 2004
      • 794
      Tacoma... I know where Burien is?
      I have an AAN but its in my B4 should I be after an ABY part?
      I also plan on using the K24R snub mount kit..
      //-\\ ((_)) //)) //
        Tacoma... I know where Burien is? I have an AAN but its in my B4 should I be after an ABY part? I also plan on using the K24R snub mount kit..
        The Burien question was meant to see if you have ever been to AudiExpo on the last weekend in June.
        Back to the snub mount, the support that bolts to the engine is different for an ABY than an AAN. The ABY part is 893199343. This is the same support that was used for the five cylinder "NG" in the 1988 Audi 90 and the 7As in the CQ and the early 1990's Audi 90 Sport 20V (7A) sedans in the US.
        Hope that helps.
        • ThatGUY
          • Sep 2004
          • 794
          Thanx... have not been to AudiExpo yet. Next year i won't miss it.
          //-\\ ((_)) //)) //
            You better not. Can't call yourself a PNW Audi enthusiast and miss AudiExpo. It was in Kent/Auburn this year at the go cart track at Pacific Raceway Park. Normally it is in Burien. Not sure where it will be in 2012 but if it is going to be, it will be the last weekend in June in the Seattle area somewhere.
            Hope you get your swap sorted.
            Dave F.
