Failed MAP sensor?
Completely wrong sorry.
The problem is probably spark not going where it should. Check the plugs.Comment
Ok. But am I wrong in thinking that there is some sort of limit where the airflow is so much more than what the engine is mapped for, causing the ecu to take some kind of action?
Sorry for slight o.t.
Leif-Helge
-91 S2 VEMS and Comp Turbo
-12 B** 530XD Touring "S2 parts transporter, and daily driver"Comment
There is enough information on this forum to read about it, sorry, I am not going to spoonfeed you.
If he was hitting MAF limiter he would have a code stored and limp mode. He doesn't, so forget the ECU, the MAF or "too much air".Comment
