Hello guys,
what do You think, what is the best IC for URquattro with 20V turbo engine? At the moment I have stock 10V IC, but I have plans to build up the engine for about 150-170HP (goal is something about 380-400HP) and off course I need bigger IC.
I don't want to modify stock bumper, so is there any solution for bigger IC?
I saw somewhere that someone put IC instead of small radiator behind front grill, but is it OK just to remove small radiator?
I also have A/C, so is it possible that only main radiator (with A/C radiator in front of it) properly cool the engine?
Is there any other solution for bigger IC without cutting bumper?
