vems launch switch
  • QuattroFever
    • May 2006
    • 1360
    vems launch switch
    Seems simple enough but want to double check been bitten by the electrical bug before making assumptions.
    Is it just a case of taking analog channel 6 and putting it to ground via a switch? Then enable channel 6 in menu?
    No relays or trickery?
    Thanks in advance.
    Volcano ABY coupe
    Ant
  • a4kquattro
    • Feb 2005
    • 411
    Thanks in advance.
    yep, that will work, but the better way is to hook it up as an "enable" switch, with the clutch pedal doing the actual launch control activation.
    That way, you dont have to remember to flip the switch off before you release the clutch
    http://www.efiexpress.com/catalog/ar...articles_id=12
    Marc Swanson
    Proprietor, EFI Express
    95.5 //S6 Avant
    90' Coupe Quattro V8 4.2L twin turbo
    93' //S4
    83' UrQ
    97' F250 7.3 diesel
    • QuattroFever
      • May 2006
      • 1360
      Thanks
      got a push button taped to the geasrstick as a temporary solution at the strip.
      Bit tricky but managed to run 13.8 without and 13.4 with so did help a little. first time i tried it lit the wheels and ran 13.9.
      All good stuff...
      Volcano ABY coupe
      Ant
