Warning light - red triangle- dashboard
  • audi4fun
    • Mar 2006
    • 111
    • Country: Latvia
    Hi,
    looking for your support and advice what is a meaning of this warning light - red triangle?
    Audi S2 with RS2 dashboard. It was fine for a long time so the dashboard change is not a case.
    Thanks.
    Owner of www.audiScars.lv
    ex-Audi S2 Coupe '96
    ex-Audi S2 Coupe '93
    ex-Audi S2 Coupe '91
    Isn't that triangle related to the hazard / warning light system (switch, turn signal bulbs and flasher). Perhaps that is a warning that one or more of those components is no longer working properly.
    • audi4fun
      • Mar 2006
      • 111
      • Country: Latvia
      What is related to lights everything is working except reverse lights. Bulbs are ok.
      • Bowlerwell
        • Sep 2005
        • 1052
        Can you pull fault codes?
        John Bowlerwell
        Electronic Engineer
        Present:
        Nogaro Blue RS2 - TOE
        Previous:
        Kingfisher Blue S2 - UAA
        Volcano Black RS2 LHD - DEX
        • audi4fun
          • Mar 2006
          • 111
          • Country: Latvia
          Not now as have no access to vagcom now. But if that will be the only way to find a solution I find a way to do that.
            maybe its because the light filter on the dash is different in the RS2? Its actully a different warning lamp
            • LHD_Kid
              • May 2006
              • 3695
              I agree.... I think this is where the hand- brake light should be.... does any other light come on with the hand-brake up, down?
              Maybe the switch is now faulty and the light is on permanently?
              Chris
                Is it significant that your low on petrol light is on, but there is plenty of petrol in your tank as per the gauge's readout ?
                • audi4fun
                  • Mar 2006
                  • 111
                  • Country: Latvia
                  Thanks for ideas!
                  1. Hand-brake light is next to left and is working fine;
                  2. Fuel level is now adapted as dashboard is on Coupe not Avant and do not influience this bloody triangle...
                  • audi4fun
                    • Mar 2006
                    • 111
                    • Country: Latvia
                    Work Shop Code:
                    4 Faults Found:
                    00544 - Maximum Boost Pressure Exceeded
                    27-10 - Implausible Signal - Intermittent
                    00537 - Lambda (Oxygen Sensor) Regulation
                    11-10 - Control Limit Not Reached - Intermittent
                    00561 - Mixture Adaptation
                    13-00 - Adaptation Limit (Mul) Not Reached
                    00513 - Engine Speed Sensor (G28)
                    03-00 - No Signal
                    Can it induce red triangle on panel?
                    Went country side today..but forgot battery for camera Had to take pictures with phone
                    • RolloS2
                      • Oct 2009
                      • 19
                      our coupe is the air bag steering wheel model and the light in that place is the air bag warning light.
                      • Bowlerwell
                        • Sep 2005
                        • 1052
                        My RS2 has the airing light on the bottom right.
                        Did you check the airbag section specifically, or just the engine for fault codes?
                        Sent from my HTC Desire using Tapatalk
                        John Bowlerwell
                        Electronic Engineer
                        Present:
                        Previous:
                        • veneto rs2
                          • Jun 2006
                          • 1022
                          • Country: Veneto
                          Originally posted by audi4fun
                          Hi,
                          Thanks.
                          My 1995 RS2 has the airbag light in that position.
                          Stefano
                          http://www.audisportclub.com/
                          http://www.s2forum.com/forum/vbgoogl...227295&zoom=16
                          • audi4fun
                            • Mar 2006
                            • 111
                            • Country: Latvia
                            Ok, I'll check airbag. Will let you know.
                            • prj
                              • Mar 2010
                              • 6308
                              Your codes are either a bad tune or a boost leak.
