I suspected that I still had a small air leak so this weekend I took the bumper etc. off to have a proper check through.
I found two loose clips (outlet from turbo and the infamous i/c Mark H mod). BTW That now makes three clips that have worked loose since the samco's fitted. I would suggets that after a couple kmiles anyone who has fitted should check the tightness, it *may* be something to do with the silicone hoses.
Once that was all done and put back together I now have overboost protection kicking in
I suspect the marginal leaks from those two clips was masking another problem elsewhere.
BTW, The boost guage was steady at 1.25 bar when overboost protection cut in.
I've now had three leaks that did not appear to cause overboost protection (outlet from turbo, i/c inlet and i/c outlet) and one leak that did (i/p to ECU).
Does anyone know where leaks occur on the pressure/vacuum line that do cause overboost protection and which points do not? so I can narrow down the search.
Cheers Jim
I suspect the marginal leaks from those two clips was masking another problem elsewhere.BTW, The boost guage was steady at 1.25 bar when overboost protection cut in.
Cheers Jim
