s2 cutting out at idle and bad on fuel
  • s2 cutting out at idle and bad on fuel
    ok im new to s2's so new to the forums aswell so sorry if im asking in the wrong place or anything
    iv had it a few weeks and its been a dream until last night when it started idling irraticaly
    from500 to 1500 and ocasionaly cutting out also seems flat/ sputtery until 2500 tonight on the way home its been cutting out everytime i stop
    cant see any obvious boost leaks or anything
    its a aby coupe if that makes any difference
    please help cheers john
    idle stabalisation valve?
      N71 Idle Speed Stabilization Valve
      Could be a vacuum/boost leak but you should start with checking and cleaning the N71 Idle Speed Stabilization valve (ISV). Some info is available here (note: AAN, ABY and ADU all use the same ISV):
      http://forums.quattroworld.com/s4s6/msgs/21853.phtml
        cool thanks is brake and clutch cleaner ok to use for cleaning this will try this tomorrow and let yous know how i get on
        cheers john
          Originally posted by jchn_smith View Post
          cool thanks is brake and clutch cleaner ok to use for cleaning this will try this tomorrow and let yous know how i get on cheers john
          Maybe but I would use to carburetor and injector cleaner instead.
            MAF, MAF connector or big air leak.
              Cleaned it out today and doesn't seem any better. Wasn't oily inside anyways. Will have a look at the maf tomorrow cheers john
                Bad news/good news: Bad news = that wasn't the cure; Good news = at least that has been eliminated as a potential problem and, oh yeah, you now have a clean ISV.
                On to the MAF and maybe the throttle potentiometer (and vacuum leaks):
                MAF (pins and their position and cleanliness to be exact):
                http://forums.quattroworld.com/s4s6/msgs/20442.phtml
                Throttle Potentiometer:
                http://forums.quattroworld.com/s4s6/msgs/20405.phtml
                  Great links by the way, been having very similar problems myself and I think I will be checking these two items out, cheers.
