Hi all, 2 questions -
Can the 3B and 7A FWs be lightened to the same weight? I'd be looking at about a 7-7.5kg effort. From pictures, it seems that a 7A item has a bit more meat added on and that either can be reduced to a similar, more sporty weight.
Are the OE 3B or 7A FWs in zero balance or do they have some built-in eccentric counterweighting at all?
Reason for asking is that I'm likely to need a stronger clutch at some point and want to look into getting things sorted, so it all bolts on... jsut like the 3B item did 4 years or so ago (sort of)
I guess the other option is a billet steel FW. Not sure where to get one of those beauties though, or cost thereof.
