urs4 oil pan gasket leaking....help
  • euro_urs4
    • Nov 2008
    • 267
    • Home: Poland Current: United States
    hey guys i noticed my oil pan gasket was leaking, so i went ahead and replaced it however, it still leaks on the top right corner of the pan (passanger side), i was wondering what im doing wrong or if there are any opinions on how you guys took this approach and if you used any kind of gasket sealant on it to?......also just to verify on the urs4 motors, the pan has this metal oil catch shroud above the pan, and the 2 gaskets are supposed to go in between this metal pan shroud? ....thanks in advance
  • pasbogdan
    • Sep 2009
    • 1160
    • Country: Romania
    never seen one leaking
    The metal plate gets between the gaskets.
    Shure it is not something else leaking and getting in that area?Double ceck.
    • terrybullwon
      • Mar 2006
      • 8782
      Did you deck the block or check the sump to see how true it is?
      Chef
      • euro_urs4
        • Nov 2008
        • 267
        yeah positive its coming from the oil pan, had a camshaft seal leak but fixed that...
        no didnt deck the block....and what you mean check the sump to see how true it is?
