audi rs2 boost spike
  • dobbin
    • Jan 2011
    • 164
    anyone had this problem, homefried so should boost at 1.7bar but finally after changing
    040 fuel pump and new 3" down pipe and exhaust car is now running better than ever but in a 3rd gear pull hits now and then 1.7 bar then drops to firm 1.5 bar, in 4th gear pull only reach 1.55 max . then surging up to 1.6 to 1.7 . no boost leaks on turbo side
    or vac side , new n75 and forge valve. i will vag com this weekend to check for error
    codes.
