Oil Temp Sensor fitment(B3 90 2.3E (NG))
  • dgacampbell
    • Apr 2011
    • 146
    Ok maybe a daft question.......
    When i go out to fit the temp sensor, is oil gonna leak out everywhere? Do i need to go get a gallon of oil before i start?
    TIA
    Dan.
    also is this the correct way round for the spring and cylinder thingy??
    TIA
    Dan.
    you will get a little dribble, but most of it will be in the sump .... unless you do it with the engine running
      Oil Temperature Sender, Oil Pump and Oil Pressure Relief Valve Info
      Originally posted by dgacampbell
      also is this the correct way round for the spring and cylinder thingy?? TIA Dan.
      This post (which contains this photo) should help:
      Original un-annotated photos were from 4WheelDrifter (Stu) *THanks*
      • dgacampbell
        • Apr 2011
        • 146
        Thanks m8, now i know exactly where it goes, was still a bit miffed lol!!
        Dan.
