MOT Time how can i put my car in Limp Mode?
  • ian4455
    • Nov 2010
    • 787
    My S2 (3b) is finally ready for an MOT, since i'll be leaving the car at the garage how can i create limp mode incase of any joy riders ?
    Thinking of disconnecting N75 pipe from wastegate.
  • prj
    • Mar 2010
    • 6308
    Disconnect the N75... but it will throw a code.
    Or - take out the spring from the wastegate. That is even more effective than disconnecting the N75, your car will be effectively naturally aspirated.
    • ian4455
      • Nov 2010
      • 787
      Thanks, I'll remove the spring.
      • prj
        • Mar 2010
        • 6308
        Test it as well, should be quite funny
        • driftin jo
          • Sep 2007
          • 2222
          don't do that !! you will then have no boost control, not even spring, will just overboost and potentially destroy your engine if all safeguards are not working properly.
          You could however disconnect the connector (electrical) to the N75, this will give you low / spring boost only .
          • mcandmar
            • Apr 2004
            • 5118
            Unpluging N75 will stop the fun. But i am not sure if that will force it into limp home mode, i would be worried about emissions if it did as it may disable O2 control?
            91CQ20v - Gone to a new home
            93UR-S4 - The Magic Carpet
            94S2Bus - The Emerald Express
            • ian4455
              • Nov 2010
              • 787
              ....reason being i've a Hybrid RS2 running 330cc injectors and 4 bar FPR, didn't want anyone else driving if you know what i mean!
              Ok so whats the best then, thought without the spring the valve would open under exhaust pressure ?
              • driftin jo
                • Sep 2007
                • 2222
                If you unplug the n75 connector you will get ~200 hp period, turbo does not matter, unless you have a none stock spring.
                • Al Wyn
                  • Nov 2006
                  • 3746
                  Best way and the way i always do it Ian is to book the mot appointment and then be there when its being done...you also get a chance to have a good look at the underside of the car when its up in the air.
                  S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
                    Agree with Al, or just remove the fuse for the N75
                    • prj
                      • Mar 2010
                      • 6308
                      You got it completely the wrong way around.
                      If you remove the spring, the wastegate will always be open due to nothing being there.
                      Please think.
                      1.4 bar spring - 0.4 bar boost
                      1.9 bar spring - 0.9 bar boost
                      No spring - no boost.
                      What you describe will happen if you insert a solid puck instead of the spring or disconnect the lower wastegate chamber.
                      • driftin jo
                        • Sep 2007
                        • 2222
                        Please think.
                        I didn't mean the spring, in the first post said he was going to disconnect the pipe to the waste gate.
                        When I was writing my reply no one had replied yet, I can see how it may look if I was saying don't remove the spring, I should have replied with quote from first post.
                        • prj
                          • Mar 2010
                          • 6308
                          Ok, sorry, I thought you replied to me.
                          My bad
                          • sidrick
                            • Jan 2011
                            • 1342
                            Best advice here and what I was going to suggest.
                            • WabTheKing
                              • May 2004
                              • 2567
                              i agree, then you can go out with them on the handbrake/brake test as it has to be done on the road or similar as the brake tester will only 2wd iirc?
